Article ID : 00409468 / Last Modified : 27/08/2026Print
    The image sometimes shifts. (Pixel shift function)
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    Due to the Pixel shift function, the image may sometimes shift.
    Pixel shift is a function that prevents screen image retention of the TV screen by shifting the image of the TV screen after a certain amount of time elapses.
    In order to prolong the life of the panel, setting the Pixel shift function to On is recommended.
    Follow the steps below to set the Pixel shift function:
    1. On the remote control, press the Dashboard (gear) button.
    2. Select Display.
    3. Select OLED.
    4. Select Pixel shift and set to On.
