Wall mounting - What are the VESA dimensions of my TV (2009-2016 models)
Instead of putting your TV on a piece of furniture, you may want to hang it to the wall. In that case, you will need a wall mount.
Look for the four mounting holes on the back of your TV. Take both a horizontal (A) and vertical measurement (B), in mm. These are your VESA dimensions, as shown in the tables below.
Bravia 2016 models
BRAVIA 2016 Models |
For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket. |
Model | A (mm) | B (mm) | Note | |
KDL- |
200 | 200 |
Compatible Sony Wall Mount Bracket: SU-WL450 (Optional). |
KDL- 32WD60x 40WD65x 48WD65x |
200 | 200 | ||
KDL- 32WD75x 43WD75x 49WD75x |
300 | 200 | ||
KD- 49XD700x 55XD700x |
200 | 200 | ||
KD- 65XD750x |
300 | 300 | ||
KD- 43XD80xx |
100 | 200 | ||
KD- 49XD80xx |
200 | 300 | ||
KD- 55XD8005 |
200 | 200 | ||
KD- 43XD8305 |
100 | 200 | ||
KD- 49XD8305 |
200 | 300 | ||
KD- 55XD85xx |
200 |
200 |
KD- 65XD85xx |
300 | 300 | ||
KD- 75XD850x 85XD850x |
400 | 300 | ||
KD- 50SD8005 |
200 | 200 |
KD- 55SD8505 |
200 |
200 |
KD- 65SD8505 |
300 | 200 | ||
KD- 55XD9305 65XD9305 |
300 | 200 |
Sony Wall-Mount Bracket supplied with the TV. |
KD- 75XD9405 |
400 | 300 |
KD- 65ZD9 |
400 | 300 |
KD- 75ZD9 |
400 | 300 |
Bravia 2015 models
BRAVIA 2015 Models |
For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals on this support page. You can also find the guide for your product by:
KDL- |
200 | 200 |
KD-43X8305C | 200 | 300 | ||
KDL- |
300 | 200 | ||
KD- 49X8305C 55X8505C 55X9005C 65X9005C 55X9305C |
300 | 300 | ||
KDL- 43W755C 50W755C 55W755C 43W805C 50W805C 55W805C 65W855C 75W855C KD- 65X8505C 75X8505C 65X9305C 75X9405C |
400 | 300 | ||
KD- 55X9000C 65X9000C 55X9005C 65X9005C |
You can use your TV's stand as part of the Wall-Mount Bracket (parts supplied with the set). You can also refer to the following video: Sony BRAVIA - How to hang your X90C series on the wall |
Bravia 2014 models
BRAVIA 2014 Models |
KDL- 32W70xB 42W70xB 42W80xB 42W81xB 42W82xB 50W70xB 50W80xB 50W81xB 50W82xB |
200 | 100 |
You can use your TV's stand as part of the Wall-Mount Bracket (parts supplied with the set). |
KDL-32R41xB 32R43xB 40R45xB 40R48xB |
200 | 200 | ||
KD-49X8505B KDL-55W805B |
200 | 200 | ||
KDL- |
300 | 200 | ||
KD-65X8505B KDL-65W955B |
400 | 300 | ||
KD- |
400 | 400 |
Bravia 2013 models
BRAVIA 2013 Models |
KDL- |
N/A | N/A |
KDL-24W605A is not VESA compatible. You can use your TV's stand as part of the Wall-Mount Bracket (parts supplied with the set). For instructions on using a Sony Wall-Mount Bracket, please refer to the “Wall-Mount Bracket Installation Guide” leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals in this support page. |
KDL- |
200 | 100 |
KDL-32R42xA | 100 | 100 | ||
KDL-40R47xA | 200 | 100 | ||
KDL-46R47xA | 300 | 300 | Before installing the Wall-Mount Bracket, attach the Attachment parts for Wall-Mount Bracket (parts supplied with the set) to the rear of the TV, using the supplied screws. Please refer to the instruction manual. | |
KDL-40W90xA | 200 | 300 | ||
KDL-42W80xA KD-55X9005A |
300 | 300 | ||
KDL-65W855A KD-65X9005A |
400 | 300 |
Bravia 2012 models
BRAVIA 2012 Models |
KDL-xxEX440, KDL-xxEX55x, KDL-xxEX65x, KDL-xxHX75x,KDL-xxHX85x, KDL-xxHX95x |
Screen size | A (mm) | B (mm) | |
22" | 100 | 100 | |
26" | 200 | 100 | |
32" | 200 | 200 | |
40" 46" 55" |
300 | 300 | |
65" | 400 | 300 |
Bravia 2011 models
BRAVIA 2011 Models |
KDL-xxEX310, KDL-xxEX32x, KDL-xxEX42x, KDL-xxEX52x, KDL-xxEX72x, KDL-xxCX52x, KDL-xxNX72x, KDLxxHX72x, KDL-xxHX82x, KDL-xxHX92x |
26" | 200 | 100 | |
32" | 200 | 200 | |
40" |
300 | 300 | |
60" | 400 | 300 |
Bravia 2010 Models
BRAVIA 2010 Models |
KDL-xxEX30x, KDL-xxEX40x, KDL-xxEX50x, KDL-xxEX60x, KDL-xxEX70x, |
22" | 100 | 100 | |
26" | 200 | 100 | |
32" | 200 | 200 | |
37" 40" 46" 52" |
300 | 300 | |
55" 65" |
400 | 300 |
Bravia 2009 Models
BRAVIA 2009 Models |
KDL-xxS5500, KDL-xxS56xx, KDL-xxV5500, KDL-xx V5800, KDL-xxW5500, |
26" | 200 | 100 | |
32" | 200 | 200 | |
37" |
300 | 300 |
