Article ID : 00235957 / Last Modified : 03/02/2022Print
My wireless noise-canceling headphones turn off immediately after I place them into the charging case
    This can happen if the remaining battery charge of the charging case is low. Recharge the charging case with the supplied USB Type-C™.
    You can check the remaining battery charge of the headphones using the Sony | Headphones Connect app (Ver. 6.0.0 or later).
    NOTE: For WF-1000XM3, the headphones firmware version 2.0.2 or later is required. Downloads are posted on your model support page.
