Before you start
- The reset method differs depending on your Soundbar model. Refer to the manual for model-specific information.
- Settings return to their initial status after a reset. Settings such as volume, function, sound settings and/or personal information stored on the system may be changed.
Reset your Soundbar
Open the expandable section below which corresponds to your Soundbar model.
HT-S100F/SF150
HT-S200F/SF200/SF201/S350/SD35/X8500/X9000F/XF9000/Z9F/ZF9
- Press and hold the
(power)and - (volume down) button on the Soundbar for more than 5 seconds. - Unplug the AC power cord (mains lead).
- Plug the AC power cord back in again, and press the
(power) button to turn on the unit.
HT-G700
(power) button to trun on the unit.
HT-S20R
- Press the MENU button on the remote control.
- Select RESET by pressing the ↑ (up-arrow) or ↓ (down-arrow) button.
- When ALL RESET appears on the front panel display, press the ENTER button. The system settings will return to the factory default.
