For how to reset the soundbar or home theater system, refer to the following:
Notes:- The reset method differs depending on the product.
- The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
- Not all models are sold in all countries or regions.
Select your model:
- BRAVIA Theatre Bar 5 (HT-B500)
- BRAVIA Theatre Bar 5 (HT-BD50)
- BRAVIA Theatre Bar 6 (HT-B600)
- BRAVIA Theatre Bar 6 (HT-BD60)
- BRAVIA Theatre Bar 7 (HT-A7100)
- BRAVIA Theatre Bar 8 (HT-A8000)
- BRAVIA Theatre Bar 9 (HT-A9000)
- BRAVIA Theatre Quad (HT-A9M2)
- BRAVIA Theatre System 6 (HT-S60)
- BRAVIA Theatre Trio (HT-A8)
If you cannot find your model:
Follow the steps below to find your product manual.
- Go to the Sony Support website and enter your model name in the search bar.
- Select your model name to open the product page.
- You can find your product manual (Operating Instructions or Help Guide) just below the Manuals or Manuals & Warranty tab.
