Article ID : 00255773 / Last Modified : 07/07/2026Print
    How to reset the soundbar or home theater system
    For how to reset the soundbar or home theater system, refer to the following:
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may change.
    • Not all models are sold in all countries or regions.
    Select your model:
    If you cannot find your model:
    Follow the steps below to find your product manual.
    1. Go to the Sony Support website and enter your model name in the search bar.
    2. Select your model name to open the product page.
    3. You can find your product manual (Operating Instructions or Help Guide) just below the Manuals or Manuals & Warranty tab.
